Bug: Copy block in custom display mode breaks viewport
I have created a custom view with the name “Shaded Texture no isocurve”.
Please see the settings in the attached image.
When I turn on shadows and I copy a block instance or I move a block instance with the alt key it breaks the viewport.
When I turn off shadows everything works as expected.
So here is a sample scene:
And this is what happens:
Hi Muhamed -
Please run the Rhino SystemInfo command and copy-paste the output here.
Rhino 8 SR17 2025-3-7 (Rhino 8, 8.17.25066.07001, Git hash:master @ b14fcd901289f8715631debb308bc919a4988e07)
License type: Commercial, build 2025-03-07
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1080 Ti (NVidia) Memory: 11GB, Driver date: 11-22-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 457.51
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 10-14-2020 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-22-2020
Driver Version: 27.21.14.5751
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.17.25066.7001
Thanks!
As far as drivers for GPUs are concerned, those are ancient. Please open the Notifications panel in Rhino and follow the links to a NVIDIA site where you can get the latest drivers for your GTX. We recommend using the Clean Install option when installing new drivers.
I have updated the drivers, the problem is still there.
If I explode the block it works, if I deactivate shadows it also works, but if I leave it as a block and turn on shadows and use command copy or alt+drag gismo it still breaks the viewport.
Rhino 8.18 have repaired this problem.
You can have a look at this post.
Thank you for that information, I am glad they fixed it.
Shall I wait wait for the official release or is the release candidate stable in generall?
Rhino 8.18 is installed and problem is fixed.
Thank you user454 for the Tip and also thank you Wim for your fast respond and help.
