Bug Copy and Paste in Blocks
bug
(Mad) #1
Whenever I try copy and paste elements inside the Block Editor (in different blocks or in the same one with no differences) by pressing CTRL+C and CTRL+V, the Block Editor window disappears, and to be able to continue to work the only solution is to use the command “unlock selected objects”.
Is this a known bug?
(Wim Dekeyser) #2
It does sound like this one: RH-45620
It is fixed in Release Candidate 2 of SR5 - which version are you running at the moment?
(Mad) #3
I´m running
Version 6
(6.4.18130.19341, 10-05-2018)
Commercial
(Wim Dekeyser) #4
If you want to, you can subscribe to Release Candidates (Rhino Options > Updates and Statistics) and check if this fixes the issue for you.
(Mad) #5
Thank you for your help! I will try to do it immediately.
