Recently I noticed that often times I have clusters where the outputs are null, but when I go inside the cluster it shows the correct values and once I save & close the cluster, it shows the correct outputs.
Here is an example:
before going inside the cluster you can see the input is there, but all outputs are null.
I have noticed this a lot lately and basically have to avoid using clusters. Ironically I had made a cluster with a custom version of “Replace Nulls” and it would often actually output null - the very thing it was meant to prevent.
Anyone else noticed this? I am on the latest version of Rhino 7 on Windows 10.
It might be connected with a plugin. I am using V-Ray for GH a lot as well as the Human plugin.
No, the same here. But if I am working on the patch and using it for a while something causes it to be “stuck” with null outputs. Then any recalculating will keep the outputs at null and only opening and then saving and closing it can get it unstuck. But its not specific to this cluster, it can happen with any cluster.
