- change layer material
- select new material in the pop up panel
- change it’s name
crashes every time
crashes every time
What version of Rhino are you using?
Can you post your Rhino info? (Command: SystemInfo).
I’m not seeing a crash, I’m only seeing that the name is not getting changed, but I might have a different version than you intsalled.
Did you get a crash dialog box up? Did you send it in?
I always send crash reports, however I do not always add text (too many crashes for that :D)
Version 7 (7.7.21145.13002, 2021-05-25)
We found the crash dump file. I logged an issue for this here:
https://mcneel.myjetbrains.com/youtrack/issue/RH-64466
The developer will take a look at it.
I have fixed this. The fix will be in version 7.8.
Br,Max
Thank you guys
