If I execute the simple command below, the brep becomes invalid with the folllowing error (that in itself has a typo ):
brep.m_V[4] vertex is not valid.
vertex.m_tolerace = -1.23432e+308 (should be >= 0.0)
ON_Brep.m_V[4] is invalid.
It looks like the vertex tolerance is not set on the new vertex after the BrepEdge has been split.
This can be fixed by calling brep.SetTolerancesBoxesAndFlags(false, true, false, false, false, false, false, false);
to set vertex tolerances, but it would be nice if that wasn’t necessary.
PlaneSurface ps = PlaneSurface.CreateThroughBox(Plane.WorldXY, new BoundingBox(-1,-1,-1,1,1,1));
Brep brep = ps.ToBrep();
BrepEdge be0 = brep.Edges[0];
brep.Edges.SplitEdgeAtParameters(0, new[] {be0.Domain.Mid});
if (!brep.IsValidWithLog(out var error))
RhinoApp.WriteLine(error);
return Result.Success;
