Brep SetTolerances() Method
while creating a Brep by code, I am getting an invalid Brep because the start and end of a loop do not match, although I have tried to set a lower tolerance and it doesn’t seem to take that into account.
Here is the message I am getting :
"brep.m_L[0] loop is not valid.\n
end of brep.m_T[loop.m_ti[2]=2]=(0.00592947,0.993256) and start \n
of brep.m_T[loop.m_ti[3]=3]=(0.00592885,0.99326) do not match.\n
brep.m_F[0] face is not valid.\n
brep.m_L[face.m_li[0]=0] is not valid.\n
ON_Brep.m_F[0] is invalid.\n"
I tried using the BrepTrim.SetTolerances() method on all trims and Brep.Repair() using a tolerance of 0.001 and still doesn’t seem to do it.
Any idea where is the tolerance to modify in order for my topology to be valid ?
Hi @ahmedwael.si,
Your error is not due to a tolerance issue - the ends of Brep trims need to match exactly.
ON_Brep::MatchTrimEnds() can help do this.
– Dale
Hi @Dale,
Thanks a lot for your response.
Is there is a way to access the ON_Brep::MatchTrimEnds() method or equivalent from RhinoCommon using C#?
https://developer.rhino3d.com/api/RhinoCommon/html/Overload_Rhino_Geometry_Collections_BrepTrimList_MatchEnds.htm
Thanks a lot @dale, that solved it
