Hi everybody
I have a problem to create brep and then cut it between 2 surfaces.
In result I have an Invalid brep
. What am I doing wrong?
21-03-23_Invalid Brep.gh (195.2 KB)
I will be glad of any help
Hi everybody
It seems that your Rhino it is not updated. I opened the script in my computer and it perfectly works.
Anyway, if you cut a surface with a plane, the resulting intersection would be a geometry located on a plane, so you can use cap holes directly just next to the loft.
Regards
I have Rhino7.0 sr 20, but after your message I updated rhino and now my version is SR28 (Rhino 7)
The error also remained
If your tolerance is set to 0.01, try 0.001
