If all geometry in a block is on locked layers, the block instance can’t be selected as though it were locked even if the block instance itself is unlocked and on an unlocked layer.
Hi Measure -
I suppose this is going to be confusing either way, but it makes sense to change it from the current behavior.
→ RH-85190 Block: Select Instance with Non-Selectable Geometry
