BUG - Beta - User Object Failed To Deserialize
I found a new bug relating to User Objects built with the new Script Editor component.
-Create a User Object from an older WIP build pre-Beta
-Save it as a User Object
-Drag said User Object onto the canvas of a current WIP build post-Beta
-It fails to load and gives the following error dialogue:
If the user object was already added to a document it opens and runs just fine.
I just can’t instantiate a new instance of it anymore.
Thank you!
Seems like something changed between WIP and Beta that broke this. It doesn’t happen between beta versions does it?
Hi @eirannejad , thanks for checking in on this!
I don’t believe it still occurs and as a result probably isn’t even something that is currently fixable traceable.
As you pointed out it was likely something between versions.
I’ll open old scripts that had the user objects populated, replace my User Objects with those and confirm that it works now.
I’ll report back if it doesn’t for some reason.
Thanks!
Thanks a lot Michael. Let me know if you still see errors in that. We also fixed the icon quality and size on the User Objects to they should behave themselves now :smiley:
Thank you, I saw those changes in a recent build! Do you anticipate support for custom icons for user objects coming again soon?
It should be already there. You can pick an icon when creating the user object and it would retain the icon
Oh excellent! This isn’t the case currently (on my end) but I’ll check today’s build for this feature! Thank you!
Hi Ehsan, just tested and I can confirm that User Object custom icons are in fact showing again.
Thank you very much!
Thanks so much for testing this :smiley:
Thank you!
