It looks like when I make a user object using the new script component, it only works in the same version.
In a different version, users are running into one of these error:
Rhino version older than mine:
The User Object could not be created as the base type is missing.
When I open a file with a different version of the script component, it’s automatically updated to the current version as I expected. But, this doesn’t seem to happen for user objects. @eirannejad
Hi Ehsan.
I only have a user object I created six months ago with the Rhino WIP. Unfortunately, I’ve deleted the other files that were not working. I’m also attaching the file I used to make this user object. It’s odd, the file opens without issues, but the user object itself isn’t functioning properly. It appears on the Grasshopper canvas toolbar, but when I use it in a document, it triggers an error.
Actually, I’m not completely certain if this problem is due to version differences. Sometimes, I encounter the same error even with user objects created using the same Rhino version. Nonetheless, I’m trying to replicate this issue. If I can, I’ll send over the file for a closer look.
I have just downloaded and tested the latest RC build, and there are many improvements. Thanks.
I can confirm that the user object from the previous service release works with this one. However, the older user object that I sent you earlier is still not working; it continues to trigger the same error as before.
