Branches Slider
How might one create a slider such that changing it’s value would allow you to preview different branches of a tree? How would the answer change if you were trying to iterate through a tree of the form {0;x;0} vs {0;0;x}?
Tree statistics -> paths -> list item (here you can insert your slider) -> tree branch
GENIUS! Thank you!
You‘re welcome :slight_smile:
Another option, Param viewer also outputs paths.
Aagain an other option would be this :wink:
It uses a plugin…
I developed this one to avoid the need of multiple components to just explore a dataTree…
every branching can be taken as a whole by double-click the corresponding slider (turns black and displays a *).
