trc940825
(Trc940825)
1
Hi everyone,
I’m trying to modify a data-tree, which has 3 layers of branch for example:
Then, without changing the written program, I would like to merge those branches in the second layer, which means I want the result like this:
I tried to make it by using “Path Mapper”, But the result is not what I want:
So How can I get the results I want?
Thank you!
a little bit hard coding but it does the job
I’d recommend managing this at the source where the data structure is generated
trc940825
(Trc940825)
3
Thank you very much Will, That works!
One more question, which is the meaning of
“path_index-a*4”
I’ve never seen this in any tutotial, could you tell me where can I learn that?
Ruichen
