i need to create a connection by one main and two sec but give component main and sec in one component to create connection
Like This in three main beam
but when i try to put main and sec ther is something make error i don’t know where is the problem ?
there is the script
You’ll probably need to flatten your main part input into a list (that has the same number of items as there are groups in the secondary input).
Check out this entry in the FAQ for some explanations and an example:
The input matching can be unintuitive even for normal Tekla components, for connections it can become really tricky. But the above example should cover many of the use cases.
Cheers,
Sebastian
