I am trying to apply a connection between a beam and a column. At some points, I have successfully applied the Tekla connection 141, but as shown in the screenshot below, I am unable to add the same or a different connection at the opposite end of the beam with another column. Could someone please guide me on what I might be missing or doing wrong?
Thank you for your response. So far, I have managed to apply all connections at each node, including the base plate connection to the column. However, if I have made any mistakes or if there is a more correct way to do this, please advise
You’re correct; I need to create a separate group combination in which one column and two connected beams will come together as a group. Can you please guide me on how to achieve this?
Thank you so much. I previously misunderstood what you meant by ‘posting the code,’ but now I realize that you were referring to my .gh file. I’m new to Grasshopper, and I’ve made some changes to my code based on your advice, but I’m still having trouble achieving the beam to column connection. Could you please review my code file? Your assistance is greatly appreciated.
thanks you for the response.
I have tried this example and I understand it. Now, I have one more question: If I have ‘n’ number of beams and ‘n’ number of columns, how can I control the pairing mechanism?
u need write a separate code for it like each column connecting with which beams u need to list them in group and apply code
there are some samples in the tekla forum too
Hello Rahul
here is two methods to do it u can find the code or script in the attachments
this works only in column to beam connection
for beam to beam connection u need to adopt different method
