Bounding box issue
[BUG]: Bounding boxes do not work:
@rheinason Do you mean the BoundingBox command doesn’t work with VisualARQ objects? any particular one? I’m doing tests but the command works.
Send the model to visualarq@asuni.com so we can check it out.
Thanks,
Yes the Rhino Command BoundingBox, it was for this particular geometry, where the Brep created is much larger than the actual bounding box.
What kind of object is that? can you send the model to us?
