Hello! suggestions are needed! does anyone know how to build a bottle like the photo I attached? I assume it can be built by twist? thanks in advance!
You could very easily build this using lofts but that is a little more on the manual work side of things. Your other option would be Twist command. Another would be a command that I always forget about and its named after a storm. Something like Cyclone or Typhoon. My brain might also be making that one up. If anyone else in the forums could identify that would be great.
I think you’re talking about maelstorm
That would be maelstrom
right?
Correct! Though I’m not sure if that command would be useful in this case.
hi! thanks so much for the detailed info!
build it straight then twist that section, then boolean subtract, or do some point editing in the area for the band using a ring shape-
