Hi
My rhino has started merging coplaner planes when i do a boolean union. (I dont know why?)
However, I would like that it didnt do that since I often need those surfaces.
Any Idea as to how to keep it from merging?
Example of this. Before boolean union
After the boolean union - they way it does it now
previous it look like this in the boolean union
Thansk in advance!
It looks like that change was made in 8.9 as a result of this issue. I opened a new issue here to add an option to not merge those faces.
Thanks! That would be a big help.
i personally really like that it merges it automatically thank you for that making my life easier
, i never needed a non merge version, but having an option is always better.
I really appreciate your help with creating a version where I can keep coplanar surfaces without merging them. I often create geometry for CFD, and sometimes I place a door inside a wall, resulting in multiple coplanar surfaces that serve different functions in the CFD simulation.
Currently, when I need to perform more complex operations with many boolean functions on more intricate geometry, I work in Rhino 7 instead of Rhino 8.
This is a simple example of the type of geometry I’m referring to.
Thanks!!
Astrid
