in the attached, boolean fails (pipe-like object - plane).
Also _wirecut fails.
As far as I see the objects are ok…
(I know how to get a solution, just wanted to report this bug.)
-C-H-A-R-L-E-S-
CP_NoBool.3dm (48.2 KB)
-C-H-A-R-L-E-S-
Thanks Charles, I filed the issue.
edit: the developer commented that since the intersection is not a closed curve BooleanDifference wouldn’t work. Were you looking for it to trim?
@BrianJ I can’t find this on YouTrack - can you please post a link here? (I searched for http://discourse.mcneel.com/t/boolean-fail but couldn’t find it).
Here’s the YT link… http://mcneel.myjetbrains.com/youtrack/issue/RH-24922
Thanks. In the future when you add bugs based on a discourse conversation, please add a link on Discourse to the YT item, and add link in the YT item back to the Discourse thread. This makes it easier to understand where bugs come from.
Hi there, I haver a problem too. I would like to boolean diffrence (so cut the pipe) from that twisted ring but I cant. Do u have any solutions?
I bet the issue is with the twisted ring self-intersecting. Please also post a new topic for any new questions if you can.
