Hi 1606739 -
To troubleshoot a Boolean operation, run the Intersect command on both objects and closely inspect the resulting intersection curve(s). They need to be either closed or end on an edge of the surfaces.
If the file is too big, just export two objects that you are having problems with and upload that.
