Hello, i have beeen trying to use boolean difference or solid difference, to cut this opennings in this surface, but some don’t work for some reason, how could i make it work.
my process is, i make various curves and then i make them a surface with planarsrfs anf then i use boolean difference but for some curve it dont work… how could i make it work.
If you can’t just select all the curves and run PlanarSrf and get the right result, then there is something wrong with some of the input. It might help to clean them up a bit of you select all the curves and run CurveBoolean, then PlanarSrf on the result, that worked for me.
