OK, so I downloaded the BongoSDK 2.0 (from here). The “BongoSdkTester” project in the download seemed to be a VS2010 project, with all its paths pointing to Rhino 5 SDK.
I have Rhino 6 though, and documentation says that Rhino 6 SDK/C++ only works with VS2017 so I updated the project to VS2017. But when I try to compile it doesn’t seem to find some files related to Rhino 6.
The project seems to be Bongo-aware though, but not fully Rhino-aware, so to speak. Unsure of how C++ projects must be configured but I tried to follow the instructions for C++ plugins on this page and I set the Property Sheet File set properly, like so:
I also modified the stdafx.h removing old paths and adding “#include "RhinoSdkStdafxPreamble.h” and at the end of the file I added “#include "rhinoSdkPlugInLinkingPragmas.h” etc to make that file happy as well, and I also modified the header files adding the keyword “override” to the “Required overrides”. I also fixed some macros which wasn’t in the mode using a fix as documented in the sooruce code,
#include "C:\Program Files\Rhino 6 SDK\inc\rhinoSdkPlugInDeclare.h"
RHINO_PLUG_IN_DECLARE
… which helped a lot, but I’m still left with 71 errors. Hopefully someone can figure out what’s missing in the project (which came with the BongoSDK 2.0) when seeing some of the errors ni the list:
The project wasn’t happy with VS2010 nor with VS2017 after all these modifications. I can create a new “clean” Rhino C++ plugin in VS2017 though, and then it compiles, but the BongoSDKTester project isn’t happy at all.
// Rolf
Errors:
Severity Code Description File Project Line Suppression State
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_3dm_attributes.h BongoSdkTester 61
Error C2065 'CRhinoPlugInManager': undeclared identifier d:\dev\cad\bongo\bongosdktester\bongosdktester\bongosdktesterplugin.cpp BongoSdkTester 96
Error C2065 'pim': undeclared identifier d:\dev\cad\bongo\bongosdktester\bongosdktester\bongosdktesterplugin.cpp BongoSdkTester 96
Error C2065 'pim': undeclared identifier d:\dev\cad\bongo\bongosdktester\bongosdktester\bongosdktesterplugin.cpp BongoSdkTester 97
Error (active) E1835 attribute "deprecated" does not apply here C:\Program Files\Rhino 6 SDK\inc\RhinoSdkDib.h BongoSdkTester 636
Error (active) E0147 declaration is incompatible with "void ON_SetBinaryArchiveOpenNURBSVersion" (declared at line 556) C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_archive.h BongoSdkTester 4609
Error (active) E0029 expected an expression C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_archive.h BongoSdkTester 556
Error (active) E0020 identifier "CRhinoPlugInManager" is undefined D:\DEV\CAD\BONGO\BongoSdkTester\BongoSdkTester\BongoSdkTesterPlugIn.cpp BongoSdkTester 96
Error (active) E0020 identifier "ON_BinaryArchive" is undefined C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_archive.h BongoSdkTester 556
Error (active) E0020 identifier "ON_BinaryArchive" is undefined C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_object.h BongoSdkTester 664
Error (active) E0020 identifier "ON_BinaryArchive" is undefined C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_object.h BongoSdkTester 684
Error (active) E0020 identifier "ON_String" is undefined C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_error.h BongoSdkTester 165
Error (active) E0020 identifier "pim" is undefined D:\DEV\CAD\BONGO\BongoSdkTester\BongoSdkTester\BongoSdkTesterPlugIn.cpp BongoSdkTester 96
Error (active) E0070 incomplete type is not allowed C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_archive.h BongoSdkTester 556
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_3dm_attributes.h BongoSdkTester 59
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_3dm_settings.h BongoSdkTester 730
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_3dm_settings.h BongoSdkTester 731
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_bitmap.h BongoSdkTester 59
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_bitmap.h BongoSdkTester 60
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_bitmap.h BongoSdkTester 258
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_bitmap.h BongoSdkTester 259
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 267
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 270
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 533
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 535
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 923
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 925
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 1075
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 1077
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 1371
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 1372
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 1443
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 1444
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 2245
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_brep.h BongoSdkTester 2248
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_curveproxy.h BongoSdkTester 212
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_curveproxy.h BongoSdkTester 216
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_detail.h BongoSdkTester 43
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_detail.h BongoSdkTester 47
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_dimensionstyle.h BongoSdkTester 424
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_dimensionstyle.h BongoSdkTester 429
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_group.h BongoSdkTester 59
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_group.h BongoSdkTester 63
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_hatch.h BongoSdkTester 412
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_hatch.h BongoSdkTester 413
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_instance.h BongoSdkTester 255
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_instance.h BongoSdkTester 268
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_instance.h BongoSdkTester 663
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_instance.h BongoSdkTester 666
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_layer.h BongoSdkTester 62
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_layer.h BongoSdkTester 66
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_light.h BongoSdkTester 46
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_light.h BongoSdkTester 50
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_linetype.h BongoSdkTester 109
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_linetype.h BongoSdkTester 117
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_material.h BongoSdkTester 143
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_material.h BongoSdkTester 147
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_nurbscurve.h BongoSdkTester 204
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_nurbscurve.h BongoSdkTester 210
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_pointcloud.h BongoSdkTester 68
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_pointcloud.h BongoSdkTester 71
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_surfaceproxy.h BongoSdkTester 77
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_surfaceproxy.h BongoSdkTester 81
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_text.h BongoSdkTester 243
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_text.h BongoSdkTester 247
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_texture.h BongoSdkTester 158
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_texture.h BongoSdkTester 162
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_texture_mapping.h BongoSdkTester 190
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_texture_mapping.h BongoSdkTester 194
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_text_style.h BongoSdkTester 169
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_text_style.h BongoSdkTester 172
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_viewport.h BongoSdkTester 142
Error (active) E1455 member function declared with 'override' does not override a base class member C:\Program Files\Rhino 6 SDK\openNURBS\opennurbs_viewport.h BongoSdkTester 158
