The Bongo 2 toolbar in the installer is made for Rhino 7 or earlier Rhino versions.
In Rhino 8 the toolbars have changed from using bitmaps to using svgs. This might cause old toolbars to look blurry in Rhino 8.
From here:
Bongo.20.V80.rui (4.0 MB)
you can download a Rhino 8 compatible toolbar for Bongo 2.
To load it in just go to Rhino Options > Toolbars > File > Open.
Hi, any idea why nothing is visible to actually use bongo 2.0? Im using rhino 8 but can’t use bongo, i have installed but nothing comes up (timeline, keyframes… nothing at all). Thank you!
Try typing the command “BongoTimeline”.
Luc
If you have installed Bongo 2.0 and there’s no Menu showing up, Rhino 8 has probably not loaded Bongo. You can run the _MigratePlugIns command. In the Migrate Plug-ins Window make sure both Bongo Plug-ins are selected in the list and press ok.
Thank you very much, problem solved!!
