I just purchased Bongo 2.0 and installed it. However, the Bongo toolbars do not show. I did do a 30 day evaluation and did uninstall it after the evaluation period was over. The Bongo toolbars remained with the Rhino toolbars after the Bongo uninstall so I manually undocked and closed them. With the install of my purchased Bongo the toolbars never reappeared. How do I get the Bongo toolbars back?
I would also like to get involved with Bongo and I can’t see the Bongo toolbars - after activating them, I only get two empty toolbars.
What version of Bongo have you downloaded and installed?
Hello Jeremy
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp | Bongo 2.0 | |
C:\Program Files\Bongo 2.0 (64-bit)\BongoUI.20.v60.rhp | BongoUI20v60 |
Try typing the command _Bongo, then go into Options>Toolbars, select Bongo.20.V60 in the Toolbars and Toolbar Groups dropdown, Then highlight the Bongo 2 toolbar - do you see the buttons at the bottom of the panel like this?
oh yes-
I hadn’t even noticed the list above ;o)
Cool – now I at least have the toolbars.
Now I’ll try another tutorial like this.
Thank you so much!
Good luck!
I am up and running withe the Bongo Menu Bars. Thanks for your help.
