SMC2
June 8, 2018, 2:09pm
1
Hi every one
we have a probleme with the rhino 6 display and cliping plane.
Display mode:
Presentation.ini
https://smc2.box.com/s/g3abtyuh8onk9de9oljqzomyfamh92ol
in rendered mode, the probleme is mor big!
P1814-IMAG_FINISHING DETAIL.3dm
https://smc2.box.com/s/6jsi82v94zop7cfdxvj7pvfxmzz5s4sx
on the layaout space with block objects, the cut view is not correct (a few line blak appears)
But if i explod all blocks then
the cute A-A is correctly display :).
the problème is: we have need all blocks
pascal
(Pascal Golay)
June 8, 2018, 3:11pm
2
Hello - I do not see this in the most recent builds here -
Presentation:
Shaded:
Can you please run Help > “System information…” and paste the results here?
thanks,
SMC2
June 11, 2018, 7:12am
3
HI,
this is my system information.
in your pictures not gosted, your display is better than my display but is wrong diplay beacause the cliping plane (cutting plane) is not placed in 6 holes!!!
If you explod all blocs, you display is it good?
Rhino 6 SR6 2018-6-5 (Rhino 6, 6.6.18156.11421, Git hash:master @ 56799860400d22a41148fb77e55b1181e81ebe7b)
Licence type: Commerciale, build 2018-06-05
License details: Cloud Zoo. In use by: xxxxxx SMC2 (Bureau d’étude)
Windows 7 SP1 (Physical RAM: 32Gb)
Machine name: PC-BE30
Quadro K2200/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 397.31)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-22-2018
Driver Version: 24.21.13.9731
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.6.18156.11421
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.6.18156.11421
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.6.18156.11421
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.6.18156.11421
in rhino 5 the display is good
if i move the cutting plane(cliping plane) then the display of cute A-A change
Best regards
pascal
(Pascal Golay)
June 11, 2018, 4:53pm
4
Hello - ok, I see so the display of the fills and edges are not working in the block, is the problem, correct?
https://mcneel.myjetbrains.com/youtrack/issue/RH-46673
SMC2
June 12, 2018, 6:55am
5
Hello Pascal,
Yes this is the problem.
thank for your help
Best regards
