Block Visibility Bug
Hey there, I’ve experienced a repeating bug in my current project. I’ve created some curve-only blocks and right after the creation, it became invisible, although it can be seen using ctrl+A. I’m attaching sample file - exploded geometry and the invisible block next to it.
Any idea?
block visibility bug.3dm (150.4 KB)
Solved by Pascal. Thanks once again.
I see the problem with the model but can’t see a workaround. On the other hand, I can’t duplicate the problem… Works fine here.
@Jonish
I can repeat the problem, not sure why it’s happening.
@Pascal Maybe you have an idea of why the closed curve is becoming invisible once it’s made into a block?
Edit: I can repeat the problem in your file with your curves. But if I create a new file here and draw some curves and make a block it works as normal.
Hi Jonas - run ClearDrawOrder on the curve before Blocking (or use BlockEdit and ClearDrawOrder after the fact) Does that look better?
Thank you, guys.
It also happened with open curves. Yes Pascal, that solves the problem, thanks again.
-jonas
