Curves in Blocks do not respect DrawOrder
Curves in Blocks never seem to be able to be in the background, they remain visible whether the drawing order is defined according to the layer or manually.
Here an exemple:
The hatches in the block react to the DrawOrder manipulation but not the curves.
CurveInBlockDrawOrder.3dm (5.0 MB)
Best,
Pip
Hi Pip -
I think you are running into this issue: RH-83874 Draw order commands don’t support Blocks
When you run one of the draw order commands and try to select a block (or have a block preselected), that simply doesn’t work. Selecting the hatch and using BringToFront sends that in front of both the hatches and curves in the block:
