[BUG] transparent curves invisible in Blocks
Seems like there is a display issue with curves inside blocks, as soon as curve color has some transparency.
To reproduce:
  1. make any box
  2. draw any curve
  3. set curve color to any color with any level of transparency other than 0
  4. make a block from the box and curve.
    Once the block is made, the curve is not visible anymore. It shows again when block is exploded or in BlockEdit mode.
At least over here, curious if anyone else can see this. thanks–
–jarek
yep, same here. changing opacity makes curves invisible if part of a block
Hi Jarek - I see that, thanks.
RH-64224 Display: Transparent curves invisible in blocks
RH-64224 is fixed in Rhino 7 Service Release 8 Release Candidate
