Hello everyone,
So I am making a block load in karamba where the kN/m value should be around 5 (as can be seen in the panel). When I view the load values of the model it displays a way lower value then needed. This doesn’t seem to be correct as my bending moment for example is also way lower then my hand calculations.
Thanks in advance
Update: also when I do a simple beam analysis the values do not represent what is the input.
simple case.gh (16.7 KB)
block_load_karamba.gh (46.9 KB)
