Does anyone have an idea why block editing takes a really Long time sometimes?
I assume it has something to do with the number of block instances and definitions you have in the model.
In my case (right now) I am working in a model with maybe 100 block definitions ans quite more instances.
I am trying to edit one of These blocks now and opening it took about 15 minutes which makes each editing really annyoing.
Is there any cure for that? Apart from using less blocks as this stuff is Input from other companies…
Hi Dominik - are the blocks inserted as linked (i.e. BlockEdit opens them in a new instance of Rhino) or embedded, so BlockEdit just works directly in the current file?
all of them are embedded.
I just looked up how many blocks there are in the document.
There are about 9000 definitions. I know thats a lot. But all this comes form external sources (Autocad). So there is no way for me to make that stuff less…
Hi Dominik - can you possibly upload a model that is big enough to show the problem (SaveSmall, Zip) to www/rhino3d.com/Upload , to my (Pascal) attention?
Hi there, I am facing same issue with block editing in Rhino 6 and 7 Windows. It takes ages to get into the block to edit it and it tooks another ages to close the dialog when it is edited. This was never problem in Rhino 5. The block contains only text instance for the drawing purposes ie. revision mark which is on all several pages like “Rev-A” i need to change to “Rev-B”. Nothing complex inside the block and block count is only about 10 instances. Why it takes so long? It is annoing while this is just simple text.
This is not possible with this file. This is running project with sensitive data, i am not allowed to share it.
And just the block itself doesnt show the behavior when you try to edit it. I think it has somethig to do with the complexity of the file.
When there is not yet any drawing in the model - the scene is almost empty, to edit any block is fast.
But later, when the drawings takes place in the scene, and there is lots of curves of the model, it takes ages to edit any block in place.
