Block Edit render displaying differently than usual
Hey all. Having an odd issue where my meshes look correct when in Block Edit mode (see first picture) but then look all wrinkled when I exit editing (second photo). Any ideas?
Hi @Maren_Speyer ,
Thanks for this post. Can you post the 3dm file please with the texture maps embedded via the Save Textures check box when using SaveAs? You can use the Export command to save out just that object instead too. Thanks.
