Hello, the model looks blown up as soon as you mirror it. Is there a solution to this?
Hi @11170 can you share that model to visualarq@asuni.com? we will check that out.
If you select the mirrored model and run the vaUpdate command, does that issue persist?
yeah it does not help
All right, in that case, please send us the model so we can reproduce this behavior and find a solution for this.
i will try to recreate it and send it to you
va problem -block mirror.3dm (684.9 KB)
Thanks for the file! It looks like the problem only happens when you mirror a block that contains VisualARQ objects. If you explode the block and mirror the geometry, the result is correct.
We will take a look at this!
thanks
Hi @11170, We have fixed this issue in VisualARQ 2.11: VisualARQ 2 - Version 2.11 released
THANKS!!
בתאריך יום ה׳, 17 ביוני 2021 ב-9:52 מאת Francesc Salla via McNeel Forum <mcneel@discoursemail.com>:
