VA Geometry in blocks
Is it the case that VA geometry and blocks still don’t mix well or is there some combination of settings that I should be using? I’m finding that VA geometry doesn’t respond as expected in Plan view when contained in blocks.
For instance, fills where objects are cut by level cut planes do not display, and door/window swings do not display.
Hi @nrkuhl,
VisualARQ objects should work fine, but it seems there are some problems when displaying them on Plan View objects.
Can you send me the model to visualarq@asuni.com?
Thanks,
Enric
