I’m new to V7 and it looks really great. I’m currently trying to figure out my workflow to get a SubD file out of Blender and converted to a NURBS surface that’s clean and ready to export as a .step file.
This is what I tried and the results were OK, but not stellar. I was expecting surfaces that I could use Analyze>Zebra or Analyze>Environment. The surfaces are polysrf and not srf.
This is my workflow:
Export out the low poly SubD mesh from Blender, the coarsest mesh for the SubD there as an Obj. Then import that into Rhino 7 and run ToSubD on it. Then take that SubD and run ToNurbs on it.
Here are some pictures of the results I got. Useable, but not OMG. I assume my next step would be to link up the longer ribs with isocurves. Rebuild the isocurves as degree 3 curves and sweep with 2 rails.
What’s happening in the areas with the poles/stars/spiders?
In another experiment I tried to bring in a scan in .stl format. Used quadremesh and then tried to use ToNURBS and things got weird. The result was thousands of individual polys rather than one big sheet surface.
Would you kindly post files/screenshots from all steps in your process? I just tried to repeat your process exactly and I got a very clean NURBS surface - so you may be making an error unknowingly somewhere along the line.
As you can see, this works. However, there may be something specific about the file that you are working with that throws a wrench in the operation. Uploading your files would be best, unless you are working under an NDA, or something.
Your unsubdivided model is much too complex. Your first thought when working with subd should be “how few faces can I get away with?” This simplifies the process drastically, and reduces the chances for errors, as well as making your model far more lightweight for the future.
For example, see my version of your helmet model. Yours has hundreds (at least) faces, while mine has ~20, yet we get very similar results when subdivided. This should be your goal - as few faces as possible.
Ultimately, I’d say you should go over your original model again, keeping in mind what I said about as few faces as possible - only add detail where it is needed in the SubD, and not before.
I’d like to upload my .blend file, but it’s not a permitted file type.
I’d love to see your blend file. I’m at the Blender forum under the same user name, if you want to send there. I’m going to review your data and get back to you with a better response. Looks hyper-interesting!
Wow. Wow. Wow! A light went off. What I need to do is have an ultra low poly base shape (<75 polys). The base shape drives the more detailed higher poly outer surface (1200-1500 poly per side). When it comes time to output a Rhino solid model> ToNURBS the base shape and rebuild as simple surfaces (CurveNetwork or Sweep2Curves. Which is best?). Then punch in the vent holes and loft to the vent tunnels.
I’m still confused about why a polysurf can’t be used for Analyze>Zebra? And what’s the best workflow to take the resulting 5 polysurfs from your simplified model and make it into a single unified surface?
Polysurfaces, surfaces, extrusions, meshes and SubD objects all work as input to Zebra in Rhino V7
Some shapes can be modeled as a NURBS polysurface but not as a single NURBS surface. Some shapes can technicaly be modeled as a very dense single NURBS surface but are very likely to have problems.
Your final helmet shape with the ribs and holes is a shape which perhaps could be modeled as a very dense trimmed NURBS surface but the results are likely to be unsatisfactory for most uses.
All untrimmed individual NURBS surfaces have four sides. One, two or three sides can have zero length. A NURBS surface can be trimmed including with holes but the underlying surface will still have four sides.
If I go to Analyze>Zebra it prompts “Select objects for zebra stripe analysis” and when I go to select the polysurface, it can’t be selected. It doesn’t seem to be locked. What am I doing wrong?
Understood that it may not work satisfactorily as one surface. Should I have a radial array of intersection planes that I make curves from intersections from? Then rebuild those curves with +/-10 control points as degree 5 and use those curves to loft a new surface? That’s what I’ve always done in the past.
I finally got a chance to go back in and review the files. I was able to analyze>zebra with no problem. And I recreated your steps and got similar results.
Going back to the topic of my original post; Soon I’ll be faced with rebuilding a complicated bike helmet shape modeled in Blender into a real world water-tight solid in Rhino. It’s going to be every bit as complicated as the (first) helmet images I attached, and conversion from subd to nurbs came through as a patchwork of NURBS surfaces. Do I use those surfs to create splines, then create surfaces off of those splines and then stitch everything together? I’ve done this cad work for 3 helmets and it’s never been easy or fun. Having a simple base shape that I could convert from subd to NURBS and use that to add more specific vents onto is about the best I can strategize. Can you suggest any ideas/strategies that would make my work easier?
