I have an observation about editing a blend surface using the in-command edit option. The blend always returns to the default shape when you go back into it. I think it would be much more intuitive and useful
if it stays where you had it and you can update it from there, rather than it switching to the default position every time.
In my example image, the pink surfaces show the blend that I’ve made between the pair of surfaces. The grey (copied) version shows me going back into the blend (using edit) and it automatically pinging to the default.
Thank you
Blend.3dm (77.8 KB)
