Bitmap Texture Settings Potential Bug
Rhino 7 SR30 2023-6-12
Windows
I have observed that if I change the texture of a PBR material from within the Bitmap Texture Settings, the RenderContentChange.None event happens.
I was expecting it to be RenderContentChange.Attach or RenderContentChange.ChangeAttach.
What am I missing?
cc: @andy
Do you have any thoughts on this @andy?
Hi @Devang_Chauhan,
The button you clicked on is just for changing the file name, not the texture. It doesn’t actually attach a new texture, it just updates the file name in the existing texture. That means you shouldn’t get any kind of event related to attaching a render content.
I’m puzzled as to why you are receiving such an event when you use the […] button. Could you send me example code so I can try to repeat your results?
Thanks,
John
