Bent plates in Tekla
I’ve been trying to creat a flange on a piece on a plate in Tekla. Which works, but it creates a another single plate to replace the previous 2. But the previous 2 remain.
I prefer not to create another plate, as previous work,modifications to the orginal plate will be lost.
I suspect it may be a tekla variable, not sure if it the direction of the curves?
Before Bent Flange
After
Flange Support Question.gh (41.5 KB)
Thanks for any help.
Thank you so much rajeev. I played with that for 2 weeks. Really appreciate your help.
Rajeev,
I put the bent plate as input into the Autobolt, and its an illegal input. I cant get it to work in raw tekla. So I’m assumining that we cant bolt bent plates with Grasshopper :frowning:
Any suggestion welcome ?
Cheers
Greg
could you attach the code
Screen flange with hole pattern v1.gh (55.5 KB)
I suspect the problem is a limitation with the the autobolt component within Tekla.
