Hello, I am new to Tekla-Grasshopper live link. I am trying to create steel plates in Tekla with varied height and it was suggested to me to create lofted plates for such cases.
I managed to create horizontal plate, however when I am modelling vertical plate with inclination, Tekla does not display the graphics of the plate and I am not sure where I have a mistake in my script.
I would appreciate your help!
But if you want to use the lofted place component you have to make sure that the direction of your curves are the same. In the below image I flipped one of them and it works a treat.
Thank you so much for the insight Oskar! This worked.
Now I have the same issue for my horizontal plate. The surface is not planar.
I think the problem might be not constant width of the plate, but I am not sure. Is there a way to fix this? Lofted Plate-2.gh (11.3 KB)
Lofted plates can be sensitive to the geometry of the input curves. Unfortunately I don’t think the situation will improve in the near future. Some observations here:
In addition to the interpolate option in the above thread I noticed that with your curves you could use the Rebuild Curve component with a Count input of 6 to give you something that Tekla likes. But that only works in this particular case and isn’t a general solution.
Hi Sebastian Lindholm,
Thank you for your response!
I have tried interpolate curve from the other thread before; however, interpolation would not be the optimal solution for my goal.
I can also create series of planar surfaces (in this case 3 segments) as simple plates; however Tekla recognizes them as 3 different plates and connection between them is also not ideal. Is there a way to combine these plates as one or “trim/extend” the ends of plates so they fit the end edges?
Thank you for your answers Mr. Lindholm. After this discussion I have tried to incorporate Tekla Components and came across with “Triangle Generation” and “Unfold Surface” components that help to create a straight plate from the one that is curved and has varied width.
However, when I model “Unfold Surface” with grasshopper, the same issue arises as before - the plate is not visible at all unless I use “convert to brep” command in GH and by selecting it I can temporarily view the plate lines as shown on the picture. However, this does not happen when I directly apply “Unfold Surface” within Tekla Structures and unfolded surface is created.
When I compare the attributes of surfaces created with Tekla Structures and with GH, they are the same (with one difference - GH surface has weld_loop 0 attribute, which other does not).
Could you have a look at my script and help me identify what am I missing?
Hi Sebastian,
Thank you for your reply!
As a result I want to get one plate, thats why I had creating_type 0.
Yet, I realized the problem was with Tekla file itself. When I tried to open it in new file, i worked as it should have. So I am still not certain what was the problem with the file but I sorted the problem.
