I tried to join two objects (surfaces) but neither “join” or “snap” worked.
You’ll find here a screenshot of the model.
I’m beginner with Rhino, perhaps I don’t use the right things. Could you please help me ?
Thanks in advance for return.
If you want to join them, you can “move” and with end osnap put them together.
Hi -
Please just include pictures right into your post. And even better, always post a 3dm file when asking for help.
I tried end snap but it didn’t work, it’s likely due to the model.
You’ll find attached the file but I don’t know to include the picture in the post (see below).
Hey, I only have Rhino 6, can you convert it to this version?
Hey,
there were some issues with the model.
I have rebuild your object using BooleanDifference and ExtrudeSrf
Hope that helps ![]()
Here is your file:
test_rhino_4_edited.3dm (1.9 MB)
Select both and Join (ctrl+J) them. It should work.
I suggest you do some tutorials, it really helped me out!
Thanks a lot for this return @Paul_96. I will try and I’ll do another model.
To do my model I used a cube (solid), made arc between each middle of each edge, joined each arc, created surfaces between arcs, and then joined each surface.
I begin now with Rhino before using Blender and mesh modeling these last years, and I still need to learn how to find and fix my topology errors with Rhino.
I watched a lot of tutorials and I still need to watch more but sometimes I although need help.
@Paul_96
Just to confirm that it works
Glad I could help! Have fun and enjoy your ride with rhino
