Hi , everybody. In this file i made conceptual design with the aid of 3 or 4 point surface component in Rhino . These parts made in 3 parts. So when i want to join 3 parts , it didn’t go well.2022-01-20T20:30:00Z
Con Yahct Design __ 4.3dm (203.2 KB)
Uploading: unable to join 3 parts.jpg…
@Mahdiyar @DanielPiker @MateuszZwierzycki
Hi -
Perhaps the easiest is to delete the two faces that are selected in this image:
Then, use the EdgeSrf
command and select these 2 edges:
That will create a triangular face that will join with the adjacent objects.
Thanks a lot. I will try.
Thank U very much. IT Solved Perfect. So this is the final Result.
Conceptual Yacht Design _44.gh (30.6 KB)
