Hello @jonm I’m back.
We need to add beam supports to our model. Have I either missed the node that does this or are you able to implement this?
I’ve attached an image of the interface where you input the values I’m talking about as well as the export of this simple beam model to show what the formatting of the text line is. A key requirement is also to specify the compression only.
Thanks again for your assistance.
Will
BeamSupportExampleText.txt (13.2 KB)
