Hi @jonm,
I am trying to import Strand7 results into Grasshopper using the
Solver-Strand7-Feature-Queries Results.gh (32.9 KB) example file as a starting point.
I am running into issues at the STR7Query component, where I’m getting a mix of “1. Solution exception:Input string was not in a correct format.” and “1. Solution exception:Value was either too large or too small for an Int16.”
I have attached below both the model file.txt and various results file.txt. I have tried exporting from the Print Preview window as well as direction from the Listings window.
Please could you provide guidance on what/where the issue is?
Thanks!
2023-11-30 - strand7 sample beam.txt (16.3 KB)
2023-11-30-strand7 sample beam_force-moment results.txt (352 Bytes)
2023-11-30-strand7 sample node reaction results.txt (199 Bytes)
2023-11-30-strand7 sample node displacement results.txt (199 Bytes)
