BEAM - Rhino and Revit Interoperability
Enhancing BIM modelling.
A workflow to connect Rhino and Autodesk Revit.
Assign parameters, create families and move geometry across the platforms.
BEAM comes with features targeted to assist designers in the creation of models that can fully deliver the creative intent along all the data needed to bring it into the digital era of Building Information Modelling.
With an intuitive interface and plenty of options, move data and geometry with ease, no scripting required.
Platforms
the plugin doesn’t work with the last Service release - candidate-
Can you provide additional info on what is not working for you? Thanks
I got this error while launching Rhino
Rhino 7 SR19 2022-5-25 (Rhino 7, 7.19.22145.11571, Git hash:master @ caa2c82dfec916fac8d9d68494573e8d3883ef60)
Please report the conflict with @mksdtech https://www.mksdtech.com/
Do you need a link to the previous version?
We have talked to the user, uninstalling and reinstalling BEAM did the trick.
BUT WHY…?
But Why…?
Hi Muhsin,
That’s not a lot to go on, please type SystemInfo in the command line and paste the results here. Current Revit version as well please. Thanks.
Rhino 7 SR25 2022-11-22 (Rhino 7, 7.25.22326.19001, Git hash:master @ 2a680490f96a04550d1f39158b859c4f7739d024)
License type: Corporate, build 2022-11-22
License details: Stand-Alone
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 7-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.94
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-21-2022
Driver Version: 31.0.15.1694
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\ProgramData\Beam\App\RHINOBEAM.dll “MKS BEAM” 1.9.0.6
C:\Users\DELL\AppData\Roaming\Proving Ground\Conveyor\ProvingGround.ConveyorRhinoInside\ProvingGround.ConveyorRhinoInside.rhp “Conveyor Rhino Setup (Rhino 7)” 3.2.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.25.22326.19001
Revit Version 2022
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
  • Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Revit Version 2022
This might explain things:
Thanks…I will buy out the original one…actually its installed for practicing purpose.
Hi Anderson,
I just installed Rhino 7 & MKS Beam to export rhino object to Revit.
But whenever i do the ‘‘Beam’’ option the below given message will pop up.
Please help me out on this…
Perhaps @mksdtech would know. Or can point you to their support.
Dude, the first and only place to look for support for some obscure plugin is whoever made it.
