Batch Rendering
Hi team, I’m wondering if anyone has any expertise batch rendering out named views? Basically I have about 10 or so named views I need rendered and want to save the time to let each one finish then move to the next one, then render repeat.
I want to just set up all the named views, then click go and have them all rendered one after the other.
Does such a tool exist?
Food4Rhino
has a few options
Thanks Will. Thea Render looks like it will work. I think Bongo will end up being cheaper for me however.
I appreciate the help. Thank you.
You can use the following script to render out all named views to a folder you are asked to specify at the start of the script.
import rhinoscriptsyntax
import scriptcontext
import Rhino
target = rhinoscriptsyntax.BrowseForFolder()
for nv in scriptcontext.doc.NamedViews:
    Rhino.RhinoApp.RunScript("-_NamedView _Restore \"" + nv.Name+ "\" _Enter", False)
    Rhino.RhinoApp.RunScript("_Render", False)
    Rhino.RhinoApp.RunScript("-_SaveRenderWindowAs \"" + target + "\\" + nv.Name + ".png\" _Enter", False)
    Rhino.RhinoApp.RunScript("_CloseRenderWindow", False)
This should work for any render engine, including Rhino Render.
Renders will be saved as PNG images in the location you selected using the name of each named view.
Oh I love this option … Thank you so much.
The only thing is I don’t really know how to run scripts other than just paste the text into the command line. Which I’ve done but then an import dialogue appears, I assume wanting to import several Libraries …
import Rhino
I have no idea how to do this or where these libraries might be found.
I have actually completed a short course in Python, but I don’t really understand much about scripting in Rhino at this stage however.
I’m sure this is like the most simple thing for anyone familiar with the process … can anyone help a noob please? Hey I’m a designer not a programmer, never have been never will be.
Run the command _EditPythonScript, create an empty script and copy/paste the code.
You can then save the new script to some location on your computer. You’ll be able to use this in the future then as well.
Dear Mr. JesterKing, you are both a gentleman and a scholar.
If you ever need any help deciphering the difference between a pinkey mauve and a blue fuchsia please let me know :grin:
I’ll let you know! For now I think I’ll manage with just buying nice flowers for the missus every now and then :wink:
Brilliant one!Thank you for sharing. :smile:
And i compiled it to a “.rhp” plugin ,so we can make it to a button,more convenient. :smiley:
BatchRendering.zip (5.2 KB)
