Hi everybody,
…I’m not a grasshopper expert… but… I would like to find the correct way for this:
I have an houge quantity of DXF cutting file on a folder.
I have to open each file, mirror and do some more stuf.
Save the file in dxf format
I’m not able to find some solution for batch operations in grasshopper… any suggestions?
Thanks in advance for any kind of idea.
Piero
Fantastic!.. I didn’t try for the name!
I supposed only for 3dm.
For save in different files?.. do you have another trick?
Thanks again!.. you open me a world …
You may also use Import From or Import To Doc from Pancake to deal with the import procedure, which gives you slightly more information than the original Import 3DM component.
