Hello - if the obects are curves that need to be squashed flat to the Cplane, use ProjectToCPlane (See also SetPt) But if you want to move objects down, but not flatten, then Move > Vertical, snap to the lowest point (if that is available) and then type in 0 and Enter.
See also, (Help file) “Tab direction lock”, Ortho, SmartTrack.
