Everybody is good! Excuse me! How do we send Windows in Revit to RHINO as glass and frames? So, you don’t have to separate layers again in RHINO
thank you very much!
thank you
Is it possible when baking using the geometry cache to have the category type as a rhino sublayer?
In the example above the Layers are by Category/Subcategory.
Model::Walls
Model::Doors::Frame
in your example all walls are in the same layer. I was asking if there is a way to add sublayers to the Wall layer based on their category types, in this case Wall types. In big models this organizations helps a lot to keep the model organized.
I understand now, you want the Element Family Types added as sub layers. I’ll add that as a feature request. Thanks!
Good advice
You may want to look at this example. It takes structural beams and creates sun layers based on element type: Rhino.Inside®.Revit
Is this sort of what you are looking for?
With a little modification it could do walls too.
