When I bake the component in gh,it just bakes in Rhino immediately without attributes pop-up to group or change layers.Please tell me how to let the attributes pop-up appears again.
Hi -
When you use the Insert key to bake a component, it will get baked without questions. When you right-click and pick Bake..., the dialog should appear.
If something else is happening on your system, for starters, please run the Rhino SystemInfo command and copy-paste the result here.
It works!Thanks a lot!
