"Bake all objects" possible bug
I’ve notice something strange and I would like to know if it is just my problem and/or I’m doing something wrong
I have the component Part cut in my definition. In some instances the cutting part is a plate, in other instances the cutting part comes from a rhino/gh geometry so I prefer to use Item component directly without remodeling it for tekla.
I select Delete on the Cut part component.
The moment I press ‘Bake all objects to tekla’, the cutting part is rigenerated if it is an Item, so i have to delete them manually after
Am I missing something?
thanks for reading
delete item in tekla.gh (24.8 KB)
here in the code i delete the CutPlane which i used to trim the beam
it might help you to solve your issue like wise
regards
rajeev
Hi Fabio, I got this replicated and yes there are a couple of issues here.
Turning off “Run in Background” seemed to make it work correctly in a first test, but that didn’t work every session. Furthermore the shape profile of the cut doesn’t seem to get baked, so at least in my case the cut becomes invalid.
This should all be working better in the new version, WIP available here:
Note that you need to upgrade the components to benefit from this (Tekla menu → Upgrade Components…), the old components will largely behave the same as before.
If you’re unable to move to a WIP version Rajeevs solution might provide a workaround!
