Bad Unlock Bug
Hi All,
I don’t have time to be writing this but need to give people the “heads-up” there is a bug where if you are editing a block and type “unlock” it unlocks everything not in the block and makes it editable (Which is awesome), however the problem lies that when you leave the block and go to “undo” it is not possible and won’t undo whatever you do to items outside of the block.
I am in the latest version of RHINO 8.
Hi Christian -
Thanks, this issue is on the list as RH-80859 BlockEdit: Undo issue
