When I import the attached step file from Fusion the through holes have an extra cylinder inside.
V6
V5
CoreWireBlock.step (185.5 KB)
Thanks Mark
V6
V5
Thanks Mark
Hi Mark - I see this, thanks.
It looks like the holes have incorrect trims - if you untrim the cylinder it takes the right diameter. I’ll get this on the pile, thanks.
CoreWireBlock.3dm (397.9 KB)
https://mcneel.myjetbrains.com/youtrack/issue/RH-44286
Hello!
If I open step files —one or another solid is missing. (Rhino 6)
No problems with the same objects in Rhino 5.
Why do You release a software that´s obviously very buggy?
Best
Simon
Hi Simon - if you have an example step file that shows this, please post it here or send to tech@mcneel.com.
thanks,
Hello Pascal,
import option works correctly for .step, .sldprt, .sldasm,
however in 5 it was possible to open .step directly without any problems.
(solidworks 2017)
Thanks
Simon
Hi Simon - so the problem you see is Open as opposed to Import, do I understand that correctly? It may be fixed in the latest, I’d like to try one of the files that has given you trouble…
thanks,
RH-44286 is fixed in the latest Service Release Candidate
Hi Mark - I think that is expected - if you untrim one of theses you’d get the full torus.
@Hughes_Tooling - is that torus floating in the middle expected or is it meant to be trimmed by the cylinders?
Never mind, I was in V5… Sigh. Is it Friday yet?
The Fusion export was updated a couple of months back and broke Rhino V5 import of tori. I think in the past the export shrank the tori and that’s why it looked different in V6. After untriming as you suggested I understand what’s happening now.
Thanks Mark
Hi Mark - got that, thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-44467
